Timing chain tensioner
Fowlz92
Post by Fowlz92 »
Looking into buying a 2009 2.0 scirocco gt, read about the issue with the tensioner just wondering roughly how much it would cost to get the updated tensioner fitted? Seen people say £3-400 but also seen People saying close to the £1000 mark
Re: Timing chain tensioner
£400 sounds about right to just replace the tensioner at a VAG specialist / indie whereas £1000 is probably at a dealer or may also include replacing the chain as well. Personally I would budget for the worst case and hope it ends up towards the lower figure.
Fowlz92
Post by Fowlz92 »
Thanks, went to look at one today where the dealership were convinced it runs on a belt, they also phoned a vw dealership who said same thing. Think ill ignore them and put some money aside just to be safe though.
On the Scirocco the diesels and the R model are belt driven all the rest are chain driven.
The confusion arises because some people think it's the same engine that was fitted to the Golf MK5 GTI because the power output was the same.
Fowlz92
Post by Fowlz92 »
Yeah had a feeling that was the case, test drove it and all seemed fine but had no evidence of a tensioner previously being changed.
Currently got 80k on the clock and just been serviced but still unsure whether itd be worth the risk of buying.
Zanic L3
Post by Zanic L3 »
I have gotten a quote here: http://www.sciroccocentral.co.uk/forum/ ... 22#p211524" onclick="window.open(this.href);return false;
Fowlz92 wrote:Yeah had a feeling that was the case, test drove it and all seemed fine but had no evidence of a tensioner previously being changed.
Assuming there are no tell tale signs on a cold start, all you can do really is budget to have it changed or if buying from a dealer, make sure there is a good warranty in place, should the worst happen.
Fowlz92
Post by Fowlz92 »
Im assuming once the updated tensioner is fitted it should be fine and wont be a need to worry about it much?
Going to pop to the garage next to work tonorrow and get an idea how Much they'd charge to do it, if its a decent price ill be putting a deposit down for it i think
Paradox1
Post by Paradox1 »
3-400 is the norm.
Depending on the mileage, you may want to do the cam chains at the same time. that would double the cost though
Fowlz92
Post by Fowlz92 »
Paradox1 wrote:3-400 is the norm.
The one im looking at is on 81k, would it be worth doing the cam chains you reckon?
Paradox1
Post by Paradox1 »
I would as a precaution
Fowlz92
Post by Fowlz92 »
Cheers, I'll have to get a few qoutes for them and hopefully the car wont be gone by then
Psycho Kirky
In: Salsa Red
Options: MODS-
K&N Typhoon Induction kit
BCS Powervalve custom sport TBE
REVO Stage 2 remap
Airtec Stage 2 Intercooler
Forge diverter/recirculation valve
Sachs Performance clutch
'Heavy Set' silicone hoses
REVO Torque Mount Insert
Various detailing
Post by Psycho Kirky »
If the timing case is being removed, it would be daft not to to replace the chains and runners too. Oil pump chain should be ok to leave, It often is. The parts aren't that expensive and shouldn't add too much labour time at all. But labour prices will sting in many places.
There is a little gauze filter in there that usually decides to break off and if i remember rightly, it isn't sold separately it is part of the unit its attached to (cant remember name) and was around £120 from VW.
Sent from my SNE-LX1 using Tapatalk
Fowlz92
Post by Fowlz92 »
Garage im planning on using charge £30 an hour labour so hoping it wont come to too much
Paradox1
Post by Paradox1 »
Fowlz92 wrote:Garage im planning on using charge £30 an hour labour so hoping it wont come to too much
Thats well cheap. most charge 50-60, yeah that will be a huge discount.
Like Kirky said, you should get the whole lot done :yes:
