Help, car wont start!
simon2015uk
In: Sumatra
Post by simon2015uk »
Can anyone help, I went to start my 09 Scirocco (2.0 tsi) if that makes any difference, and at first I noticed an error say "Airbag fault"
Then I went to start the car and I just get 3 beeps and a repeating clicking sound and dashboard lights flickering when the key is turned in the ignition, so the car wont start
Ive waited half hour to see if that helped and I am getting the same issue
The windows dont work either so I cant put them up!
Does any one know what this is??? :(
darkvisje
Options: Done: Rns315 with bluetooth, Steering wheel with f1, full black trim, blacked out dipped logos. Xenon, full LED interior + DRL
Coming up: AP Coilover set, 19inch black gloss wheels, dipping my winter wheels black.
Re: Help, car wont start!
Post by darkvisje »
Battery dead!
Verzonden vanaf mijn iPhone met Tapatalk
Karnivore
Options: Panoramic roof, RNS510, 19" Talladegas, Bluetooth, Cruise Control, H&R springs, Revo cold air induction kit, Milltek turbo back exhaust, Helix sporting organic clutch, LUK flywheel, Ade tuning custom remap.
Post by Karnivore »
darkvisje wrote:Battery dead!
Agreed
Another vote for a flat battery.
simon2015uk
In: Sumatra
Cheers guys, are you suggesting that I need to charge the battery, or do I need to buy a new one?
simon2015uk wrote:Cheers guys, are you suggesting that I need to charge the battery, or do I need to buy a new one?
Charge it first to confirm that's the issue but if you're battery is over 5 years old then I would consider buying a new one.
Karnivore
Post by Karnivore »
I agree with CupraBob, charge it first and see if it's holding charge.
Did you leave the lights on or anything, that you know of? It's unusual for a battery to drain unless it's faulty. Either way, charging it is a start then you can rule that out , but hopefully it's just a flat battery.
simon2015uk
In: Sumatra
Not that I am aware of, 'im going to charge it and see what happens! Thanks all :)
simon2015uk
In: Sumatra
Hi guys, well i have an update, the ignition now turns on and the cars starts! BUT, with the engine running all the dash lights are flashing and there is just constant beeping!?
mattyfitz
Post by mattyfitz »
They should reset once you have driven it down the road and back, but if your battery should be replaced if it cant keep the charge.
If it's the steering and ESP light that are on, they will go off once the car is driven and the steering angle sensor is recalibrated.
Before the car started was it turning over fast or slow? Low voltage on modern cars can cause a few issues / warnings.
simon2015uk
In: Sumatra
Ok, ive taken it for a drive, and it is the ABS/Traction/Handbrake lights that are flashing along with the constant beeping
And its still flashing and beeping! :(
Karnivore
Post by Karnivore »
Get an OBD2 reader from ebay and see what codes it comes back with.
I've got this one: http://www.ebay.co.uk/itm/Universal-Car ... SwU-pXss5U" onclick="window.open(this.href);return false;
Then check the codes here:
http://wiki.ross-tech.com/wiki/index.ph ... ault_Codes" onclick="window.open(this.href);return false;
That'll tell you what you're up against, if you're confident that it's not going to cause major damage you can clear the codes with the reader.
