Heating/Climate Control Died
RYANWOOD4
In: Night Blue
Options: Matte grey with gloss black highlights - H&R springs - 18" Y-spoke alloys - R Cup rear spoiler - Carbon fibre interior - more to come...
Post by RYANWOOD4 »
Hey,
Hoping someone can help.
The heating/climate control in my Scirocco has completely died.
No air blowing at all (on any setting, hot or cold).
I've changed the blower motor in the hope it was that, but that hasn't helped.
Plugged Carista in and get the following faults;
00538 - Reference Voltage
01809 - Actuator for temperature flap on the left (V158)
01810 - Actuator for temperature flap on the right (V159)
01272 - Positioning Motor for Central Flap (V70)
00710 - Defroster Flap Positioning Motor (V107)
01274 - Air Flow Flap Positioning Motor (V71)
01273 - Fresh Air Blower
00819 - High Pressure Sensor (G65)
01592 - Air Quality Sensor (G238)
Now it seems everything has failed :/ The fuse seems to be OK.
Any ideas?
Thanks in advance.
Roy_01
In: Sumatra
Re: Heating/Climate Control Died
Post by Roy_01 »
Sounds like a dead control panel or maybe worth checking the connectors on the back.
To have it listing so many faults it has to be something fundamental. If the fuse(s) are definitely OK and all the connections are good then possibly try swapping out the control panel as suggested above.
RYANWOOD4
In: Night Blue
Post by RYANWOOD4 »
Cheers for the suggestions.
The panel works, I mean I can adjust the settings, the only thing of note is that the LED temperature displays don't light up anymore (passenger and driver side), but all the buttons, fan speeds light up.
Would that still suggest the panel?
