Hi guys,
Doesn't Scirocco R have a belt or chain? From searching I can see the 2.0 model has a chain but can't see nothing regarding the R
Timing belt
Re: Timing belt
R model still uses the older EA113 engine which has a cambelt.
Other 2.0 litre petrol models use the EA888 engine which has a cam chain.
Re: Timing belt
Ah ok, thanks. Mines a 2011 which has done 36,700 miles, should I be looking at changing it soon?
Re: Timing belt
VW UK recommend that the belt and tensioner are changed at 5 years. While at it, it makes sense to fit a new water pump too.Matty81 wrote:Ah ok, thanks. Mines a 2011 which has done 36,700 miles, should I be looking at changing it soon?
http://www.volkswagen.co.uk/owners/serv ... elt-change" onclick="window.open(this.href);return false;
