V13 maps for RNS510
paddyz1
V13 maps for RNS510
Post by paddyz1 »
Can anyone recommend a good site to download V13 maps or which is the best seller on ebay or even someone want to sell their copy to me?
I just get spammed when I tried two sites and they were even all multiple rar files
paddyz1
Re: V13 maps for RNS510
Post by paddyz1 »
Also I can't reply to any PM's as I have only just joined and the system is not allowing it yet
chelspeed
Options: Sold it!
Post by chelspeed »
Got some V12 maps going cheap (free). I've changed to a my15 car so got Discover media now instead of RNS510 hence haven't upgraded to V13 and V12 is spare. Bought mine from ebay, had a search in buying history to see where from but the seller is no longer registered so no help.
The threshold for PM's isn't huge so reply to this saying thanks and you'll be almost there. A few more random shit posts and you'll be away.
thecrofter
Options: Tracker, Recaro Seats, Pano Roof, RNS510, Dynaudio, Cruise, Black Gloss Folding Mirrors
Post by thecrofter »
My RNS510 says map version 8117. How does that relate to V12/13?
2.0 TSi 280 R DSG Rising Blue / April 15 - 11 March 20
2.0 TDi 170 DSG R-Line Indium Grey / June 12 - April 15
2.0 GT TDi 170 DSG Salsa Red / May 10 - June 12
OryxSciroccoR
In: Oryx White
Post by OryxSciroccoR »
thecrofter wrote:My RNS510 says map version 8117. How does that relate to V12/13?
Version 8117 is V11 I think. V12 is 8195 and mine is version 8348 which is V13.
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Post by dimexi »
I have recently downloaded and installed v13 maps on my RNS510, works fine. Best thing was it kept all my POIs, so I still have my speed camera data.
Anyway - I bought more DVDs than I need, so I have quite a lot of spare double layered DVD +Rs that might go to waste. I am happy to copy the maps for someone and send it out, PM me so we can arrange something.
Also, something to note - PLEASE ensure your RNS510 can accept DVD +Rs, as I couldnt get any -Rs, and I know the unit can be a bit funny
tommy
Options: 19" Lugano anthricate alloy wheels
DSG gearbox
Cup Spoiler
Heated leather seats
VR Cold-Air intake
BCS Full Turbo Back 200 Cell Sport exhaust with black ceramic tips
RNS-510
Ecotech Performance remapped
Forge big brake kits 6 pots 356mm front
Forge big brake kits 4 pots 330mm rear
Post by tommy »
dimexi wrote:I have recently downloaded and installed v13 maps on my RNS510, works fine. Best thing was it kept all my POIs, so I still have my speed camera data.
Hi mate, can the new map be installed for all RNS510? I'm not sure what version mine is, I have a 61 plate.
P44RYT
Options: Airlift Performance, Rotiform TMB 3piece 2&3" polished lips, Full 2015+ R Facelift, R-Line spec, Stage 1 remap, Black splitter & skirt extensions, Twin exit PowerFlow exhaust, Carbon Fibre diffuser, Full RamAir, Full interior & exterior white LEDs
Post by P44RYT »
I have an RNS315 is it still the same software used? If they can even read DVD rewrites ..
Sent from my Nexus 4 using Tapatalk
https://www.instagram.com/p44ryt/" onclick="window.open(this.href);return false;
Viking
Options: None
Post by Viking »
RNS315 won't update with RNS510 maps. First up, they only have a cd player in the RNS315 and RNS510 maps are on dvd. Second, the maps updates on the RNS315 are via a "Single Use" SD card bought from a reliable source (like the main dealers). Once used in a machine it becomes locked to that machine only, so you can't buy it and then copy it or pass it on when used. If buying second hand, you're buying something which is worthless as it won't work.
tommy
DSG gearbox
Cup Spoiler
VR Cold-Air intake
RNS-510
Post by tommy »
Can anyone kind enough to send me the map update or link to a map update? I have seen a few online but I am not sure which is suitable for mine and I definitely don't want to screw it up.
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Post by dimexi »
You have to be above firmware 3xxx I think. Do you know what firmware your RNS510 is running?
Viking
Options: None
Post by Viking »
Maps will install on any unit with any firmware version, as long as the firmware hasn't been "modified" to reduce the size of the maps partition on the hard drive.
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Post by dimexi »
Viking
Options: None
Post by Viking »
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Post by dimexi »
^^ I didnt know that...
On my RNS, I have changed the partition for the maps though - so maybe that's why I needed to upgrade my firmware. All works fine anyway
tommy
DSG gearbox
Cup Spoiler
VR Cold-Air intake
RNS-510
Post by tommy »
dimexi wrote:^^ I didnt know that...
Where did you get yours from? I'll check mine later when I get home.
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Post by dimexi »
Where did I get what?
Maps? Firmare? partition software?
tommy
DSG gearbox
Cup Spoiler
VR Cold-Air intake
RNS-510
Post by tommy »
dimexi wrote:Where did I get what?
Maps. I'm not too bothered about firmware if it's not required to update the map.
Viking
Options: None
Post by Viking »
You can update the firmware on earlier units with 2*** firmware to get the new version of POI (Points Of Interest). You need to go up to a 3*** version or higher. Or you can just install the maps on the lower firmwares and not get the use of the POI functionality.
tommy
DSG gearbox
Cup Spoiler
VR Cold-Air intake
RNS-510
Post by tommy »
Anyone got a link to where I can buy a map update for this version? Or can I trust these downloads on http://www.my-gti.com/3868/volkswagen-r ... repository?
I only want to update the map as mine is so old now it doesn't recognise a lot of postcodes, appreciate any help with links for V12/V13 maps!
Thanks!
