Yes, that's a DAB antenna. Although as you say your unit doesn't have DAB so perhaps someone had a different unit retrofitted before you bought the car, and they took it out to put the original non DAB unit back in.
Yes, as long as they left the wire in and didn't cut it off when they de installed it. However, you'll still need a GPS antenna for the sat nav to work. Then it'll need some coding doing as well.
Viking wrote:Yes, as long as they left the wire in and didn't cut it off when they de installed it. However, you'll still need a GPS antenna for the sat nav to work. Then it'll need some coding doing as well.
I went for the rns 510 led + dab as I managed to get it for a bargain ! Yh the dab cable was there also managed to find out some fun facts about the car which VW didn't mentioned such as the car had a full sub and sound system , and has JL audio speaks all round.
