Cornering
Re: Cornering
Never had the back end break away or come close on bends or smallish roundabouts taken quite quickly .
- selleym
Re: Cornering
Nope never had the back end out properly even throwing the car around trying to see if it will slide! No luck especially with the stability control keeping it all in check!
Running Slicks?
Running Slicks?
Re: Cornering
You checked the tread on your tyres?
Re: Cornering
Check your tyre pressures assuming you don't have ditchfinders fitted on the rear☺
I do get lift off oversteer but only when I'm trying.
- whiteDevil_170
Re: Cornering
agree with cuprabob i get lift off oversteer if I'm giving it some , absolutely terrible if you're a bit over enthusiastic on a wet roundabout
Re: Cornering
Cheers for the replies. Tyres are half worn so shouldnt be a problem. Tyre pressures are ok (Ive always put 32 in) should that be different? Its a bit like oversteer tbh but surely shouldnt happen when im not giving it some
Re: Cornering
I felt a little too much oversteer when I bought my used Scirocco. When in the rain I didn't have to drive to that fast to feel the back end loose in small roundabouts... I checked the tires and the rear ones were already "outdated", the previous owner bought some used tires and, although they still had a nice tread, the grip was awful. Got some nice tires on the back axle and the car is now perfect, never felt any oversteer again..
Re: Cornering
Might have to check out what Tyres are on as ive not checked the make of them. May just be crap ones
- uklee
- I drive a: GTS TDI
Re: Cornering
VW recommend 35psi all round
From my phone
From my phone
Re: Cornering
Cheers Lee. Ill put more in later
Re: Cornering
I never over steered, even when i tried on snow. However, a few years ago i had fitted some cheapo chinese tyres to my previous car and my God! I was doing 360 pirouettes every time it rained.
- I drive a: R-Line
Re: Cornering
Wow, no never.
I'd check the tread on the tyres and the PSI of the tyres, VW suggest way more than I'd put in myself, pretty sure mine are 32PSI.
Were you accelerating hard and then lifted off mid-bend?
Re: Cornering
No Monkey81. It was coming off a roundabout into a slight left hand bend. Mine are 32 but apparently VW suggest 35. Gonna get round to putting some in tonight to see if that helps
- uklee
Re: Cornering
Check the label in your fuel filler flap - like most VW's . The specified tyre pressures are listed there. I ran mine at 32psi for about 1000 miles ( I was experimenting with the handling & ride) . The ride was less harsh but when I re checked the tread depths they were showing signs of under-inflation. I soon went back to 35psi all round.
From my phone
From my phone
