Hello everyone
I recently bought my 10plate GT 2.0tdi (140), after having a few things done e.g gauge sweep and cornering fogs the garage that did it for me also scanned the car for malfunctions.
It brought up a fault that we erased, I drove it for a few days and returned to see if it come back which it unfortunately did!!
Its brining up faults with the AirCon but the garage were unable to identify them, Could someone have a quick look to see if you can give me some information or maybe identify them as im now stuck, with no AirCon.
Codes:
B10ABF0
B10A115
B10A129
B10A111
Would appreciate any help, and ill love you forever!
Aron
HELP - Fault codes unkown
Re: HELP - Fault codes unkown
Are they VW fault codes or Ross Tech ones as they do not come up by searching the Ross Tech fault codes so no idea what they mean.
- Huttchy
hello, it was done on a 'Autel MaxiDAS DS708' I believe, the garage rung the VW dealership and they were unable to convert the fault codes.
What should be the next step?
Would have thought the garage would be able to find the fault codes. There is an Autel forum for registered users that might help. Failing that either go to the stealers who will charge £60 minimum to run the diagnostics, an independent VW garage who will charge less or find someone on here close by with Ross Tech VCDS to run the diagnostics and buy them a beer. Could buy the Ross Tech kit yourself but not cheap.
- Huttchy
Okay thank you, I was thinking of taking it to VW but £60 is alot for just getting the codes... I will ring the garage tomorrow see if they can track them on the registered users.
What is the easiest way to find someone on here close to me? and i was thinking of getting the Ross Tech VCDS for xmas -.-
Sorry been away, hence the delay in replying. If you want to find a VCDS near you just advertise on the VCDS thread and see if there is anyone then PM them.
