trix wrote:Can we start with you going under the seat & get the part number off the current rsap bluetooth box, I don't believe you have ever given us this info when we have discussed your cars bluetooth before.
From there someone should be able to tell you which part number box you need to replace it with for proper bluetooth.
Hi Trix, i'm new on here so not quite sure of this has been answered anywhere else, apologies if it has. Basically, i'm having the same issues, i have a 2009 2.0 GT with an RNS 510 head unit and 5N0 035 730B BT module under the drivers seat. My iPhone 6 will not recognise the car although the car recognises the iPhone but tells me it is not compatible. I also tried with a Samsung and a Nokia running Windows Mobile, all gave the same results, "Phone is not compatible"
Which BT Module do i need to buy to sort this problem out please?
I've tried resetting the BT unit by switching off the ignition, unplugging the unit, restart engine without unit attached, shut down again and reattach the unit and it is still looking for the previous owners Nokia, even after a reset??? I've also reset all the network settings on my phone and still no joy.
![Cry :cry:](./images/smilies/weeping.gif)
