Options: 19 inch lugano alloys , Metal pedals, satnav , DAB , leather , parking sensors , Red footwell LEDs , white led interior , hkb door sills , Needle sweep ,Horn beep on open/close , big speedo, drl deactivated, cornering fogs, An ocd for keeping it clean! Gloss black mirrors. revo stage 1 remap
Dazarooni wrote:I spent over 4 hours earlier washing the car. Alloys and bodywork washed, shampoo on bodywork and all purpose cleaner for alloys with a brush. Bodywork and wheels towel dried. Trim gel used on all exterior trim.
Cheers, it had a winter protection detail a few weeks ago and I've had a fair bit of snow here since and haven't had a chance to clean it until today. I try to wash it every week, weather permitting. I enjoy it!
Options: HID's, VCDS tweaks, interior & number plate LED's, DTUK stage 2, Kenwood head unit, black VW badges, covered cup holder, H&R springs, BCS Rear exhaust, OCD detail by the man himself.
Been busy recently, all silver trims are now gloss black, treated the door rubbers to some of that gummi stuff, new wiper blades, r-line darker rear lights and the best bit, got my headlights back and I now have xenons!
Gave mine it's final wash of the year.
It was filthy and needEd cleaning off as I won't have time to do it until mod January. Off to Australia on boxing day.
Options: CC RPS Focal 165 VRS Fronts HBK Sills and chrome fog rings La Prealpina Aero Roof Bars off for now Bluetooth done now Chrome exhaust tips (yeti) Recessed front plate
Walter got a clean, a coat of Sherbert Fizz, and some powermaxxed winter coat plus a quick wheel clean and a slow drive round the block to remove surface rust on the discs - he's very jolly now
Have a great time Down Under Jack - Merry Christmas all
fitted bonnet gas struts - fairly easy job, pretty sure the bonnet isn't aligned properly now but nothing seems wrong or fouling anywhere - all works. Definitely a mod worth doing.
Since installing the xenons I've not been happy with them been on all the time as DRL's. So out with VCDS and a bit programming later, the xenons are no longer DRL's and switched the drl function to the side lights.
Today i installed the Kimun1 interface from Kenwood to get the climatronic settings on the screen of the head unit. The dnx525dab is specially made for vag cars. It has a perfect fit. It has the on screen climatronics, pdc, 2 camera inputs. Also steering wheel controls work, and mfa display also showing song/radiostations names now. For the turn by turn signs in the instrument cluster you need VCDS if you didn't had a navigation installation before.
Go to module 19 - can gateway and go to installation list. Now check the box 37.Navigation and save coding. Restart you car and you will have a navigation screen added wich will show the turn by turn signs when you are following a route in you navigation.
For this all to work you wil need a special interface from kenwood CAW-KIMUN1 wich cost 180 euro. This will only work from MY 2010 onwards. My car is build somewhere in June 2009 wich is the MY 2010 version. The unit works with iphone and Android. It's also possible to control your phone with the touchscreen of the radio. You will need an extra cable for that to work. The unit has Garmin navigation software installed on it. " onclick="window.open(this.href);return false;
