Winter Problems / Faults, Anyone else?
Re: Winter Problems / Faults, Anyone else?
Might as well turn the lights off when the headlight washers deploy at night anyways, the few seconds of blackout always amuse me when I'm driving back along the few country roads back from my GFs at night
My car sometimes tells me it needs a service in 300 miles (which it doesn't). It doesn't come up on the MFD every time I start up, just when its been left in the cold for a long time. It's booked in to be looked at after xmas
Sat at work bored off and want to change the blown headlight wash fuse without the manual being here. Can anybody help? I couldn't even work out how to get the lid off the engine compartment fuse box! Numpty me.
Just for reference, it is opened as illustrated here. Its not in this fuse box that you need to access.Manno wrote:Sat at work bored off and want to change the blown headlight wash fuse without the manual being here. Can anybody help? I couldn't even work out how to get the lid off the engine compartment fuse box! Numpty me.
You will need to put a flat blade screw driver or car key in the slot where the green arrow shows. Lever off and all will be revealed.
Its fuse SC36 in the dash fuse box located behind the driver's side end panel. Its a yellow 20A fuse. Third row up, fifth fuse from the front end of the car.
Thanks RW1. Sorted now. :-)
- miniman
Sorry to ressurect this thread, but i just had to say thanks, its helped me out no end.
A Thing Of Beauty Is A Joy Forever
The only winter problem I’ve seen this week is rapid steering wheel movement when I press the loud peddle. Resolved by an ear to ear grin
- miniman
Sorry,should have mentioned, i was referring to the fuse layout.
Thanks again.
Thanks again.
