turn signal on constantly, vagcom.
Re: turn signal on constantly, vagcom.
Yes, i do have that on my vagcom, but it doesent do anything for me. I guess the scirocco R version have some issues making that happen :S
Cjaay90 wrote:Yes, i do have that on my vagcom, but it doesent do anything for me. I guess the scirocco R version have some issues making that happen :S
You will need to have your side lights or dipped beam on for it to work.
That doesent work either, sorry to dissapoint you:P
- Roy_01
If you can't do it with VCDS it's possible with VCP >MY2010
With VCDS set byte 18 module 9 to 00 eeprom setting.
Then use VCP PQ35 BCM programmer to set indicators to work as stand light with dimming value 14.
When using PQ35 BCM programmer, first save your light settings to have a back up you can always restore.
