Scirocco R folding mirrors
- Roy_01
Re: Scirocco R folding mirrors
Just get in contact in your area with someone who has it if you only want to change 1 or 2 things.
- Karnivore
Alex can code these, based in Redditch (he fitted my bluetooth module and fixed my cruise control as well)
http://vw-retrofit.co.uk/
- RoccoR
Hi dubber72,
I just read your posting. Three weeks ago I took delivery of a brand new Scirocco R. It did not have the electrically folding mirrors, which is something I really wanted. Last week a independant VAG master tech, did some retrofits to my new Scirocco including cruise control and installation of electrically folding mirrors. He also progammed the module so that mine close when I hold the lock button on my fob. He also changed the puddle lightbulbs with LEDs. I'm very happy and it was a good price. If you are going to go down the route of getting this done by someone then I can highly recommend this guy and put you in touch. Just PM me for more details. Hope you're enjoying your R
This is mine:
5DA269AF-F7FA-4EC1-ACBB-5E6D17982F9E by jonathan freeman, on Flickr
This is mine:
I can retrofit new folding mirrors and code them to fold on lock.
https://www.facebook.com/VCDSDiagnostic ... 162672016/
I have genuine VCDS, VagCAN Pro, SMOK and ODIS for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
- 3t3p
I need this! What is VCP?!
VCP (Vag can pro) or the new name VCP system is a similar interface like VCDS but will allow u do to a bit more then VCDS, like flashing3t3p wrote:I need this! What is VCP?!
- tinkythomas
Hi, have tried this procedure with VCP but the security code 04354 doesn't work. Anybody have any ideas why this might be?Stefano82 wrote:The procedure with VCP is not a secret anymore.
I do the same procedure without VCP: I program straight the EEPROM.
Here the VCP procedure :
http://youtu.be/g9x7IuEaHJQ
My Golf:
http://youtu.be/Bf8loXinepM
Good luck
Any help would be great appreciated, would love to get this working.
Sent from my LYA-L09 using Tapatalk
- tinkythomas
My Golf:
Good luck
