2013 Scirocco R from Belgium STAGE 2 (NEW COLOR!)
- In: Pure White
Re: 2013 Scirocco R from Belgium STAGE 2 (NEW COLOR!)
What terminal was the pics taken? ANR?
- darkvisje
nette bak! Where are these photos taken
No updates, just enjoying the car... Still searching for a good and solid diffuser.JmeDub wrote:updates?
Thanks. Pictures of the wintermodus are taken on the site 'Steenkoolmijn Waterschei Genk' ;-)darkvisje wrote:nette bak! Where are these photos taken
Just read this topic from start to finish. Car looks incredible, loving the matte grey and black! Your photos are pretty top notch also.
Matt
Hi timo,
I have a 2010 1.4 tsi Rocco, color is silver heres a quick pic of her http://www.sciroccocentral.co.uk/forum/ ... &mode=view
The car is lowered on Eibach sport line lowering springs (Should be getting KW coil overs in the future though)
I was considering The VMR V710, and I have seen that you used this wheel,
I really like how you achieved your stance and wish to do something similar.
I thought to go with 18 for a more comfortable ride
VMR have recommended 8.5 with ET35
But I see you have used 9.5 ET 45.
Did you have any problems or needed modifications to run this?
What is my best option as I can't really understand all the figures and its getting confusing.
Thanks for your time and help.
I've sent you a PM!Firstcarscirocco wrote:Hi timo,
- In: Pure White
PSA ANR?mvb12 wrote:What terminal was the pics taken? ANR?
the best!
sent you other PM when you have time
Pictures are taken at the Port of Ghent (Belgium) ;-)mvb12 wrote:PSA ANR?mvb12 wrote:What terminal was the pics taken? ANR?
Hi Timo,
It is really very nice build, I went through it and it is really amazing and I like your care about details
I have similar question of Firstcarscirocco, I have 1.4 TSI Rocco swapped to 2.0T FSI that will have my MKV big turbo build (Builds are in signature).
I am running the VMR 710 18"x8.5J ET35 all around and it fits very nice.
I have the 235/40/18 all around and I want to go for 255/40/18 in the rear.
I am thinking to have the 18x9.5 ET45 in rear, do you think it will fit?
I checked on willtheyfit.com and I found the new outer rim will poke out 2.7mm more than before and the new inner rim will be 22.7mm closer to the suspension strut compared to the existing wheel.
http://www.willtheyfit.com/index.php?wi ... 5#isPage=1" onclick="window.open(this.href);return false;
I have no problem with the 2.7mm out but I am afraid of the 22.7mm closer to the suspension, I am running VWR StreetSport PLUS Coilover Suspension.
http://www.racingline-performance.com/v ... suspension" onclick="window.open(this.href);return false;
Appreciate your opinion
Scirocco R Build! (Fun, Tough & Cost)
http://www.sciroccocentral.co.uk/forum/ ... 13&t=21372" onclick="window.open(this.href);return false;
MKV Build!
http://www.golfmkv.com/forums/showthread.php?t=195173" onclick="window.open(this.href);return false;
MKV Build!
Plenty of space in the back mate :-) Put a little negative camber on it and you'll be fine.Mostic wrote:Hi Timo,
