Could someone point me into right direction regarding this noise?
Thanks in advance!
What is this noise? Adivce needed-SOLVED!
Re: What is this noise? Adivce needed-
In case if someone would run into the same problem:
It turned out that A/C compressor was weared out. Despite the fact that it was faulty, AC worked fine, all pressures was great. After i replaced it with a new, noise completely disappeared.
