acc possible issue
dougroc
Options: heated leather seats
acc possible issue
Post by dougroc »
Hi Guys,
Just a quick one. Has anyone ever had their ACC switch starting to flash. But when you turn the engine off and back on again all has been fine. Its only happened twice but I'm just wondering if anyone knows what it might be?
Thanks in advance for your help.
mike-p
Re: acc possible issue
Post by mike-p »
Yes it's happened to me a couple of times, no faults showed up on VCDS.
Hasn't happened for a while now so I've not bothered to check with the stealer.
If it continues take it back for a checkup.
Life's too short to go slow
Skoda Yeti 4x4 Elegance 2.0CR
RW1
Legend
Hi from Sunny Stopfordia
Post by RW1 »
Two things commonly possible......
@ dougroc,
Check your shock absorbers for leaking oil, particularly around the electrical connection near the bottom end of each unit.
@mike-p
Above applies but also yours is old enough to have problematic software in the ACC controller 14. Affects Sciroccos prior to Wk45/10. Somtimes there can be faults if the ACC light flashes, sometimes not. Associated with low battery charge (volts). Charge the battery.
Refer: 2024725/1 Old software either 0069 or 0070. Revised software at 0071 (Look in the "Component Field" of VCDS Open Controller screen.)
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
dougroc
Post by dougroc »
Thanks for your help there guys! If theres any further problems, I can take it to the dealers, but I just wanted to have a few suggestions first cos u know what they r like!
Gilez
Options: Folding mirrors, luxury mats, Black leather interior, DAB RCD510 Radio, Sill Protectors
LED side, interior, number plate, puddle and footwell lights.
DRL coded off, so side lights only. Beep for alarm set/unset coded on.
Build Week 5 2010
10.02.10 - on the boat to the UK
20.02.10 - Took delivery
Post by Gilez »
The same happened to me once ages ago, but it hasnt done it since. One of those thing I guess.
maq
Options: 19" Black Luganos/Style Pack, Vienna Leather, Parking Sensor, RNS-510 + VIM patch, VW Bluetooth & A2DP, Cruise Control, Aluminium Pedals
Post by maq »
I had this happen twice on my Roc, contacted the dealers who performed a 'firmware update' to resolve (I say that in quotes, as I have no idea what firmware/software they updated, however it has cured the flashing ACC light)
As you said, turning off and on again clears the issue but its nice to have it fixed properly.
M.
