Vibration from engine bay
ayeaye
Options: Candy White Scirocco - August 2009 - March 2013
Now replaced with a MINI Cooper S
Post by ayeaye »
It may be coincidental, but since getting my DSG problem sorted out, I've noticed from time to time a loud resonance in the car. Having checked everything inside, figured it must be coming from the engine bay.
Took the car round to a mate's with view to putting it up on his ramp in case it was something underneath, but after poking and prodding a few things the noise sounds like it's coming from the common rail unit and most likely the injectors. According to my mate, injector 2 is vibrating more than the others - after he stethoscoped the area and then he felt the vibrations between no. 2 and the others were different. I couldn't really tell to be honest, but then that's why he can pull his car to bits and replaced compressors and what not and I open the bonnet and top up fluids!
When the car was in for a service advised dealer of the problem and of course "no fault found, that's normal". Hmm, definately not normal what I'm hearing.
I've managed to pin it down in the past week as it only happens when the engine is warmed up, but not at full dual carriageway running speed - something with oil temp in the 80s. Revs between 1000 and 1800, disappears after 2,000rpm but that may be due to general engine noise masking it rather than disappearing.
Going to get back onto the dealers and demonstrate the problem, but does anyone with a little (ok, a lot) more technical know-how have any ideas if a faulty injector would cause a loud and rapid clicking/ticking noise? Or are we looking at something else - I'd rather have a better idea of what the probable cause is than give the dealer carte-blanche to tear the engine apart.
Paul
ayeaye
Re: Vibration from engine bay
Post by ayeaye »
Reading another thread just now made me wonder if I had updated this thread - turns out I hadn't.
Eventually, after 7 months of being annoyed with the resonance, turned out to be that a piece of rubber around the bonnet stay had moved slightly and was causing the stay to vibrate when closed - so something else to check when trying to investigate annoying rattles or vibrations coming into the cabin.
Annoying though as I had checked the bonnet stay but the end that clips into the bonnet - hadn't checked the end that's secured to the bodywork.
Terryrussell1952
In: Dark Oak
Post by Terryrussell1952 »
For what it is worth I have had exactly the same problem with mine, the bonnet stay, it took 2 mins to cure but months to sort out!
Terry
