lights in the footwell
Can some one tell me if the lights in the footwell should stay on whilst you are driving permantently at night for example
Re: lights in the footwell
You can change this in settings in the mfd...I think it's settings, lighting and then I think it states footwell lighting or something else obvious...you can make if brighter/dimmer in increments...
I found it really annoying and turned it off after the first time I drove the Scirocco at night.Would be better if they were dimmed LEDS or similar...something not so bright as a bulb in the footwell...BMW do something similar with really small LEDS that emit a really faint orange glow.
I changed mine to red bulbs and then dimmed them down using the dash controls, they now cast a feint glow over the footwell which I like.
Hadn't thought of that...may need to give it a try...Ian_Mac wrote:I changed mine to red bulbs and then dimmed them down using the dash controls, they now cast a feint glow over the footwell which I like.
- silver130
I have done that too, but not put them on permanently.Ian_Mac wrote:I changed mine to red bulbs and then dimmed them down using the dash controls, they now cast a feint glow over the footwell which I like.
IF IT'S NOT BROKEN
I'VE NOT TOUCHED IT YET !!
I can understand they come on when you get home and are about to leave the car, but should they be on when you're driving?
