RCD 510
RCD 510
Just purchased a year old 2.0TDI 140 GT and it has the RCD 510 - I was looking for one with sat nav and would like to upgrade - appreciate some guidance re after market options and costs.
Re: RCD 510
Thanks, just had a look, there seems to be a few versions for sale - should I be looking for a vC? Most of the units are from Eastern European sellers and are used - does anyone have first hand experience of buying a used one from Eastern Europe - also most sellers say this is simple to fit at home - I am not the best DIY person as am a bit nervous about doing this myself what tools do I need and does anyone have an idiots guide to insllation?
- Shaun
Re: RCD 510
Most units for sale are second hand, i know of a seller who is trusted if you want the info, fitting is just a matter of removing a trim panel and then 4 screws, you undo the connectors and then connect up the RNS , fit a GPS Aeriel (which just plugs in and sits just above the RNS) then push the unit in and screw it back up and put the trim on, for a proper installation and to prevent errors on the canbus VCDS should be used to program it, but its not usually needed if your not worried about the errors.
Oh and i would get a C version with the LED screen
Re: RCD 510
Thanks, I would be grateful if you can pass on the details of someone reliable, I would prefer if it was programmed properly, does anyone know of someone in the Glasgow/Edinburgh area that can do this?
- Shaun
Re: RCD 510
Its this sellerkafraig wrote:Thanks, I would be grateful if you can pass on the details of someone reliable, I would prefer if it was programmed properly, does anyone know of someone in the Glasgow/Edinburgh area that can do this?
http://www.sciroccocentral.co.uk/forum/ ... rty#p64687" onclick="window.open(this.href);return false;
Re: RCD 510
Is there another way I can make contact as I am unable to PM as I have not made enough posts.
- Shaun
Re: RCD 510
I have mailed him and asked him to come over here
- Sootchucker
Re: RCD 510
Like Shaun, I've know the seller for quite a few years.
Not only is he a top bloke (and honest as the say is long), but what he doesn't know about Nav units, CAN Gateways, MFSW's, Convenience modules, Central electrics modules (well you get the point), isn't worth knowing (and a damn sight more intelligent than any dealer I've dealt with).
Re: RCD 510
Thanks - I am sure he will be in contact with me soon.
David
David
- Shaun
Re: RCD 510
Sorry but he has got back to me and he has stopped selling them :-(
Re: RCD 510
Try this Site http://www.oemretrofits.co.uk/index.html" onclick="window.open(this.href);return false; Many have used them and they will do the coding and free installation days in certain locations. I'm using them when I take delivery in March.
Regards to all
Jeff
Regards to all
Jeff
