Springs - H&R and Eibach & Swaybars?
oda
Options: no options allowed...though i would love Dynaudio and Keyless...
Post by oda »
Hello all, i am wondering whether Eibach and H&R has made a set of specific springs for Scirocco R yet? or is it the same part as for Scirocco 2.0? how much does it lower the car by and does it feel a lot harsher? (i've heard that H&R lowers more but its a lot harsher than eibach?) and for Swaybars, did H&R make a set for the R or its shared between 1.4 and 2.0?
thank you and sorry if there are any similar threads, i've searched but there isnt much info specifically for scirocco R..
juniorbanks
Re: Springs - H&R and Eibach & Swaybars?
Post by juniorbanks »
Not sure on Eibach but H&R def do see here: viewtopic.php?f=50&t=7620" onclick="window.open(this.href);return false;
They lower the car 35mm !! I think you are getting confused with coilovers which can drop it over 50mm.
In regard to the searching there is an entire forum devoted to the R as well as multiple mod threads
R forum: viewforum.php?f=33" onclick="window.open(this.href);return false;
Chungster
Options: One of the 1st Roc R owners in the UK :)
Post by Chungster »
Eibach are "still" developing a set of springs specific for the R.
H&R ones are NOT specific as they have springs according to axle loads. The ones suitable for the R is used for the TDI Roccos too ( and the 2.0 TSI with DSG box)
oda
Post by oda »
juniorbanks wrote:Not sure on Eibach but H&R def do see here: viewtopic.php?f=50&t=7620" onclick="window.open(this.href);return false;
I've seen a post by andy stating that he has h&r springs specifically for rocco r that lowers the car by 25mm rather than the normal 35mm? But i couldnt find anything on h&r website, and what i meant was ive searched over the r forum but i couldnt find much info on springs regarding specifcially on R
juniorbanks
Sorry i shouldnt post when doing 2 things at once... Yes the H&R part number 29013-2 are the compatible springs for the roc R and yes only drop between 20-25mm if you want more you need coilovers which will take you from:
29014-1, lowering 20-50mm
29000-1, lowering 40-70mm
Chungster
Post by Chungster »
The R is already 10mm lower than Standard GT so if you use these H&R Springs they will lower the R a further 25mm only.
And the info is on the H&R site :yes:
Jane
Options: Gone forever.... :-((
Audi TTS... Making me :-)) again
Post by Jane »
And to add to all of the above (which is correct), I have had these fitted since last September, the ride is not harsh at all, no problems with speed humps etc and the ACC works fine, if you look at chungsters mini dyno thread on here in the R section he took some photos of our cars together to compare height difference, so should give you some indication of looks at least :yes:
I was also told R specific Eibach springs were in the pipeline last August, so glad I never waited as still no sign !
Shaun
Post by Shaun »
here http://www.sciroccocentral.co.uk/forum/ ... 006#p65006" onclick="window.open(this.href);return false;
It does look good, does it feel any worse than before ?
Jane
Post by Jane »
Feels a firmer ride yes, but TBH I can't now really remember what it was like before, it's like child birth, you soon forget ! I like a hard ride anyway :eyepop: and I would certainly NOT describe it as that at all or harsh, doesn't feel uncomfortable on long journeys at all. Looks sooo much better, holds the road better, how it should be really. :)
oda
Post by oda »
Chungster wrote:The R is already 10mm lower than Standard GT so if you use these H&R Springs they will lower the R a further 25mm only.
I see, thank you, so they are the same springs you mean?
and i couldnt find any info on H&R on our Scirocco, only the old generation ones, any link please? :D
http://hrsprings.com/scripts/appguide.p ... &MakeID=38" onclick="window.open(this.href);return false;
Chungster
Post by Chungster »
That's the US distributor site.
You need to use http://www.h-r.com" onclick="window.open(this.href);return false;
Have fun! :yes:
H&R makes 2 types of Springs for the Scirocco, and which one is suitable for your car depends on whether your cars max front axle load is over 1200kgs or not
oda
Post by oda »
Chungster wrote:That's the US distributor site.
Have fun! :yes:
Thank you for clearing things up! btw, since i've never driven the R before, do you think the stock swaybars are good enough? or is it worth to change also? thats cus i could get a discount if i do it together with the springs :D thanks!
So what you mean is that i should go for the 29013-2 as stated above? that includes R, is that correct?
maybe you should drive it as these things are often down to personal taste
oda
Post by oda »
anyone has news about eibach's progress on scirocco R springs? if not, maybe i will just go for H&R
Chungster
Post by Chungster »
I've given up on Eibachs and ordered some H&Rs instead.
oda
Post by oda »
Chungster wrote:I've given up on Eibachs and ordered some H&Rs instead.
any comments on the H&R's? :D
Chungster
Post by Chungster »
Not driven it much since fitting but looks better! Janes car feels fine with them.
I will do a proper test soon :)
Lumiya
In: Silver Leaf
Post by Lumiya »
I've got a 61 plate 2.0 tsi dsg with Dcc. I've had my Rocca lowered with H+R springs around 7 months ago. Not sure if I need to get the Dcc reset, but my springs move in the shocks, you can hear it creak and pop while turning at low speeds. Was told it needed time to settle down but I basically think lowering with DCC on the car is a bad move.
