I tested my old A4 in the garage, and length was the main issue there. As the roc is shorter than the A4, no issue there - or so I thought.
Turns out that the roc is much wider than the A4 and only fits in my garage because I ended up with a car with folding mirrors, which were not part of my original order spec.
Without the folding mirrors, I don't think I would get past the garage door.
So just be careful if you are squeezing your car into an older, narrower garage.
