Retrofitting a RCD510
SpootNICK
In: Opal Silver
Options: PDC, Cruise Control, Leather, Paddle-Shift Gear, ECC, Bluetooth
Post by SpootNICK »
Hi guys,
Just retrofitted a RCD510 into my 09 Roc. The car came fitted with a rcd310, so instead if upgrading through the dealer i chose to buy a unit on ebay and fit it myself. It really is a simple plug and play job, and the bluetooth kit/PDC intergrated without a single glitch. While I was at it I installed a small powered sub under the passenger seat. Tapped into the rear speaker channels for feed, and took the ignition source from the cigarette lighter. Total job took 2 hours, and the end result looks and sounds awesome. Total upgrade cost less than 350 pounds equivalent, bargain!
Im in South Africa - the 510 did not come standard n our Roc's.
ktmdave
Options: BiXenon headlamps
front fog lights
510 6CD radio with touch screen
Chip Logic 200HP ECU flashing
Custom paint on grill surround
Kufatec BlueTooth module
Heated leather seats
Cruise Control
Re: Retrofitting a RCD510
Post by ktmdave »
My 140 Tsi came with the RCD510 (I was lucky - it had the bi-zenons, fogs and RCD 510 - all as I wanted)
BUT - please tell me more about the powered sub that you installed.
I am in Cape Town david@jetvac dot coza
The Don
Post by The Don »
Where is the mic for the cars buiolt in bluetooth? is this installed even if you dont get phone prep, and becomes active when you buy the head unit?
Shaun
Post by Shaun »
The mic is in the interior light unit on the roof, and if you didnt spec bluetooth it wont be there, you need the mic and a loom that goes back to the headunit.
SpootNICK
In: Opal Silver
Post by SpootNICK »
The bluetooth kit that i installed is a Parrot unit that i bought From these guys.
https://www.1stvwparts.com/product_info ... ts_id=1090" onclick="window.open(this.href);return false;
It intergrates with the headunit, stearing wheel controls......and I installed the mic infront of the steering wheel below the the instrument cluster. Very easy install.
There are a few powered subs available. I think the car sound geeks in SA call them 'bakkie' subs. It fits under the passenger seat very easily. Mine is an Audio Bank powered sub with a built in amplifier.
Hope this helps
