Hi Bo Jangles,
I’ve just typed this all out once and lost it just before I went to hit “Submit”... argh!!!
![Cry :cry:](./images/smilies/weeping.gif)
Here goes for a second time!!!
The regime you’ve got planned looks great and very in-depth! We would probably just make a couple of alterations if it were us, but to be honest if you wanted to stick to what you’ve got planned you won’t really go wrong.
The first suggestion we’d make would be to clean the wheels first. I can see the logic in doing the snow foam stage first, however, we recommend to clean the wheels to start off with because it removes any dust, dirt and brake dust that could otherwise get splashed onto the paint work. Also, it means that if you splash any wheel cleaner onto the paintwork it gets washed off thoroughly when you snow foam it (not that it will do any harm even if you do, as Bilberry is a great wheel cleaner and won’t affect the paint work – it just means it gets removed thoroughly before you hand wash the car).
The regime then looks great up until the “protection” stage, which is where we’d probably make the second change. Dodo Juice Need for Speed is an excellent product if you’re pushed for time, or if you don’t enjoy spending hours cleaning the car, however, from the sounds of it you’re going to be quite dedicated to the upkeep of your car and personally, I think you’d get better (and be more satisfied with) results if you applied a pre-wax cleanser followed by a Carnauba wax rather than using an all-in-one product.
Our recommendation would be to either go with a Lusso combination of Revitalising Creme followed by Oro (which would be our number one choice) or you could go with a Dodo combination of Lime Prime Lite followed by either Blue Velvet of Purple Haze, which would also achieve excellent results on Rising Blue.
http://www.autoperfection.com/shop/Luss ... ories.html" onclick="window.open(this.href);return false; - this picture is a little out of date and needs updating as we’ve changed the applicators to these...
http://www.autoperfection.com/shop/Auto ... cator.html" onclick="window.open(this.href);return false;
http://www.autoperfection.com/shop/Dodo ... 250ml.html" onclick="window.open(this.href);return false;
http://www.autoperfection.com/shop/Dodo ... elvet.html" onclick="window.open(this.href);return false;
http://www.autoperfection.com/shop/Dodo ... -Haze.html" onclick="window.open(this.href);return false;
If, however, you did want to stick with the Need for Speed we would recommend applying it with a microfibre applicator because we’ve found that these work better with this product than a foam one does. You could go for something like the AutoGlym Perfect Palm Applicator (although not ideal if you have huge hands!!!) or the RaceGlaze Pocket Applicator.
http://www.autoperfection.com/shop/Auto ... fibre.html" onclick="window.open(this.href);return false;
http://www.autoperfection.com/shop/Race ... cator.html" onclick="window.open(this.href);return false;
With regards to the wheel sealant, you could use a microfibre for this, but you would probably find it easier using a foam applicator. We have some small foam wedges that are excellent and we’ll happily throw one of them in with your order for you.
With the Tyre and Trim Dressing I know Trix has mentioned that there’s been people who have had issues with using a dressing, but from our own experience, we’ve never had any issues. We’ve always used our own, which we just spray on and leave (or apply using an applicator and leave if it’s a windy day) and we’ve never had any issues.
http://www.autoperfection.com/shop/Auto ... 250ml.html" onclick="window.open(this.href);return false;
For the interior we’d recommend going for something like the Poorboys Natural Look Dressing. It does exactly what it says it does, and gives a natural look, rather than a slick glossy finish, which I think looks much better than it being shiny. You could just simply wipe over the dash using a damp microfibre, but we recommend using this product as it has a UV absorber, which helps to protect the interior as well as making it look great. One of our standard yellow microfibres would be excellent for this, as they’re great for all-round general purpose use.
http://www.autoperfection.com/shop/Poor ... -16oz.html" onclick="window.open(this.href);return false;
And finally for the interior we have a Fabric Cleaner that can be diluted to different ratios depending on how dirty the seats are, but to be honest, if you’re cleaning the car every couple of weeks and you hoover them out regularly you should only really need to look at cleaning them if you end up spilling something on them.
http://www.autoperfection.com/shop/Auto ... Clean.html" onclick="window.open(this.href);return false;
I think that just about covers everything you asked, but if there’s anything else you think of or there’s something I’ve missed, just let me know!
Hope this helps
All the best
Taryn and Jim
