Took delivry of my new Rocco last Thursday..............and have now found out I cannot connect to my RCD510 system via Blutooth.
Is there anyway of upgrading or dding this option now ?????
Pete
Blue Tooth Mobile Connection
Re: Blue Tooth Mobile Connection
I can't quite understand whether you have had the factory fit 'bluetooth' (rsap) fitted & it doesn't work with your phone or you were expecting to generally be able to connect a phone to the radio with bluetooth without any specific options, assuming the first you could fit the skoda bluetooth module which will allow the 'bluetooth' (rsap) to actually work as bluetooth as everyone thinks of it, see links for parts needed & explanations
http://www.sciroccocentral.co.uk/forum/ ... =bluetooth" onclick="window.open(this.href);return false;
if this is not the case & you wanting to retrofit a bluetooth system then search 'fiscon' & 'parrot' which are retrofit phone kits the first being fully integrated the second having a separate screen, hope that helps
