Please HELP if you can CAR WONT UNLOCK
flippervw
Options: merlin pack
Post by flippervw »
Hi . Please help if you can. :mad: my one month old 2.0 Tdi is sitting on my drive blocking two other cars in!!!!! neither of the cars key fob will unlock the vehicle...
all the paperwork is inside the car so I would have to wait until tomorrow to call any dealers.....
Darn Great!!!!! Has anyone else had this happen.
Ive not had a VW for years and im not impressed as you can imagine............ :? :grumpy: :grumpy: :grumpy: :cry: :cry:
x5pea
Options: Black Leather, Sat Nav
Re: Please HELP if you can CAR WONT UNLOCK
Post by x5pea »
should be able to get in with the key, think there is a cover on the drivers handle that comes off ( the bit that is fixed) its too cold to nip out and check mine :shake:
maybe dead batt?
iAmbu
Options: Factory fit: Black Vienna leather, Dynaudio, 19" Lugano alloys
Retro-fitted: H&R springs, REVO Stage 1, OEM VW parking sensors with OPS, RNS-510 sat nav, Video In Motion, FISCON Basic Plus Bluetooth, TPMS
Post by iAmbu »
Yep check the drivers door handle, you will see that there is an end cap on the handle. Look on the underside of the handle, you will see a slot - use the key very carefully to prise this cap/cover off, and you will reveal a key lock which you can use to unlock the door! This is the official way to remove the cap, according to the Scirocco manual.
Good luck!!
iAmbu
flippervw
Post by flippervw »
Thankyou very much it worked!!! I cant understand why it failed but now I know Excellent Thanks Again!!!!! you saved me a 3 mile walk in the morning!!! :nod: :yes: :clap: :hyper: :hyper: :hyper:
iAmbu
Post by iAmbu »
Glad it worked :D :yes:
iAmbu
ZephyR
Post by ZephyR »
Same happened to mine a few weeks ago - although I did know about the hidden keyhole. Its been OK since.
Kev
Administrator
Post by Kev »
iAmbu wrote:Yep check the drivers door handle, you will see that there is an end cap on the handle. Look on the underside of the handle, you will see a slot - use the key very carefully to prise this cap/cover off, and you will reveal a key lock which you can use to unlock the door! This is the official way to remove the cap, according to the Scirocco manual.
Good luck!!
Very useful to know!
I've added it to the wiki.
http://www.sciroccocentral.co.uk/roccop ... ck_The_Car" onclick="window.open(this.href);return false;
Stuartb
Options: Cornsilk/black leather, parking sensors, Dynaudio. Fitted RNS 510.
Post by Stuartb »
Just had this happen on day 2 of ownership, so thanks to this thread we got in again - panic averted. Thanks.
