Scirocco DPF Delete Downpipe
- In: Ultra Violet
Hi, anyone know of any cheap DPF delete Downpipes that will fit my VW Scirocco 2015 Facelift 150BHP Manual Model? I heard some A3 DPF delete pipes can fit but unsure if this is the case? Can someone help please thank you
- I drive a: R-Line
Re: Scirocco DPF Delete Downpipe
just search on eBay or go to a exhaust fab shop and have one made. not a easy job tho as the sub frame has to be dropped to remove oem pdf
Before buying, ask the seller for engine compatibility, or better yet, check your engine code (found on a sticker in your boot or service book).
oyostepper.de offers the following products online: stepper motors, planetary gear for stepper motor
