Hello!
I have a Scirocco 2011 1.4TSI 122HP with a 6 speed manual transmission. Now I have an issue with my clutch pedal and transmission. Whenever I press and release the clutch pedal, I hear a squeak coming from the transmission. It sounds like it might be the clutch fork, but I'm not entirely sure.
I have already unbolted the slave cylinder and applied some grease to it
As well as to the clutch fork in the areas I could reach . Please see the attached pictures.
Can anyone help identify the source of the sound and suggest a possible solution?
Here is a video with the sound when I press and release the clutch pedal (
Many thanks!
Clutch Pedal Squeek
Clutch Pedal Squeek
