Clicking/Clunking noise when coming to a stop or setting off
Chronos121314
Post by Chronos121314 »
Any ideas as to what this noise could be? Clicks when setting off and coming to a stop, sometimes clunks.
Had it since my front suspension was replaced? Wishbones, control arms, tie rod ends, shocks top mounts replaced.
They said they had to adjust the front subframe so maybe the bolts?
bigkris06
In: Pewter Grey
Re: Clicking/Clunking noise when coming to a stop or setting off
Post by bigkris06 »
If it wasn’t there before the work was done, take it back. That is not right and it’s the responsibility of the person who did the work in the first place.
I have replaced numerous suspension parts over several years and not once have I “adjusted” a front subframe? I have only ever had to do anything to a subframe when it has sustained some sort of damage (ie accident damaged etc)
percy_tc
Post by percy_tc »
Did you fixed it?
