Hey
So my tpms will not reset pressed button in glove box for 10 seconds no bong or anything jsut flashes on dash and reappears
Anyone any ideas what it could be
Possible faulty sensors if so anyone know how to check
Much appreciated
Tpms will not reset
Re: Tpms will not reset
Check the connection to the reset button in the glovebox as they are known to come loose.
With regard to sensors, the TPMS uses the ABS wheel speed sensors to detect a drop in tyre pressure. If one of them was faulty you would get an ABS & ESP warning light on in the dash.
Exactly as Bob says.
I assume you have checked the tyre pressure?
To be fair Kris the actual tyre pressure is irrelevant and whatever it is it won't prevent the system from resetting. As it uses the wheel speed sensors it's a comparative measurement from a datum value when the system is reset.
I should have known that
They don’t have the tyre pressure sensors in the wheels.
Op - ignore me.
Cheers Bob
Op - ignore me.
Cheers Bob
