Brake disc size help please
Wozza_York
In: Ultra Violet
Options: Stage 1 remap (195bhp)
Post by Wozza_York »
Hi please can somebody help regarding the brake disk & pad sizing. I have looked on ECP website and there is a few different sizes.
I have a 65 plate R-Line 2.0 TDI
19” wheels
Please can somebody take a look and send upload the link.
Thanks in advance guys.
finetrond
Re: Brake disc size help please
Post by finetrond »
Could be these. if it's a 170hp car.
Front Brakes - Disc dimensions : Vented Discs (312 mm)
Rear Brakes - Dics dimensions : Discs (253 mm)
https://www.ultimatespecs.com/car-specs ... %20rows%20
and if it is not a 170hp then its the smaller sized disc for the front.
Having said that, i have no idea what 65 plate is in Metric.
Collector of warning lights.
chelspeed
Options: Sold it!
Post by chelspeed »
Take the wheel off, get a ruler........ Sorry guess i lost you with the first one.
Wozza_York
In: Ultra Violet
150bhp
19’’ wheels
235/35/19 tyres
Wheel / tyre size have no bearing on the size of the brake discs, it's based on the power output.
You need to double check but I believe the 150PS (148bhp) diesel uses the same size front discs as the earlier 140PS (138bhp), which ìs 288mm vented as opposed to the 312mm vented used in the higher power 170PS / 184PS diesel models. The brake pads are common between the 288mm and 312mm discs.
With regards to the rears, all the diesels use the same size, irrespective of power output, 253mm solid discs.
Easiest way to confirm is to measure the ones currently fitted to the car.
Grant310
In: Ultra Violet
Post by Grant310 »
I have a 65 plate r-line, 148hp, 19 inch wheels. My fronts are 288 and the rears are 256.
