Help!!!!.....rough idle
- In: Pure White
Hello i wonder if anyone can help....my car has devolved a running problem misfire....rough idle....loss of power... was told it would be the Pcv valve so had that replaced and still doing it?!....when you disconnect the Pcv valve pipe off the manifold it runs lovely???? Any ideas what this could be? Ive been told to discount both the pipes to the Pcv valve and run a catch can instead will this work??...HELP PLEASE SOMEONE
Re: Help!!!!.....rough idle
Had same issue. Turned out to be carbon build up on intake valves.
Sent from my SM-G960F using Tapatalk
- In: Pure White
Ok brilliant thank you i will get someone out to do a carbon clean
