Hi all,
Looking for some advice regarding changing contaminated oil after injectors was replaced after it became stuck open causing a misfire. Had a friend do the work for me, in total replacing 2 injectors, plugs and coilpacks, and the problem is now resolved. At the time I had no idea the oil had to be changed after this kind of thing so nothing was mentioned; however I've since checked the oil level (as I regularly do) and noticed a slight petrol smell.
I feel like changing the oil is a fairly straightforward task and would rather do it myself if I'm able to rather than calling in more favours. Oil extractors look the simplest way of doing this, without the need of getting under the car and messing with sump plugs (worried about torquing/stripping the thread, or worse finding the previous owner stripped the thread) - my question is, do these work well with the scirocco engines/sumps and would this be an advisable way to remove contaminated oil?
From what I've researched the extractors do not remove all the oil and leaves a little amount in the bottom of the sump, but from what I've researched a little petrol in the oil isn't too much to worry about so would this be ok once diluted down into new oil.
Appreciate any help, including recommending oil extractors if it's an advisable way of doing it.
Replacing oil with an extractor after injector failure
itisgeorge
- Dreamer
Re: Replacing oil with an extractor after injector failure
I’ve been draining oil for years from the sump plug. You will still have small traces in the engine and sump.
I recently purchased and oil extraction pump. Best thing I’ve bought in years.
If in doubt fill with cheap correct grade. Run it for a 100 miles then drop it and fill with fresh oil. Job done and it will stay clean for a long time[emoji41][emoji106]
- Roy_01
Works perfect, been using a Pela 650 for years now.
itisgeorge
Fantastic, thanks both for your replies.
Can you see any issue removing petrol contaminated oil? As I’ve been shopping around some pumps seem to carry a warning that they shouldn’t be used to extract petrol/flammable/hazardous liquids, not sure if this is related to the plastic material or if there are any other risks. In my case it’s obviously not neat fuel though.
Is the Pela 650 worth the money compared to the cheaper ones like the Pela 6000?
Thanks again and appreciate replies!
- Dreamer
If it was neat petrol maybe but it’s just oil with traces of petrol. Not a problem.
This is the pump I use. https://www.amazon.co.uk/dp/B01M0UN2RT/ ... eFbM2PSBPD
itisgeorge
Perfect, thanks for your help. I've ordered a pump and just need oil now!
- a4gee
How much was the new injectors? How did you know they were faulty? What was the test?
cheers
cheers
itisgeorge
Can't remember exactly but I think parts cost were around £100 each injector. Basically the engine suffered with a misfire, and the coilpacks had been changed a few months back so they were ruled out. Next the spark plugs were changed but the misfire persisted.a4gee wrote:How much was the new injectors? How did you know they were faulty? What was the test?
cheers
Each cylinder was compression tested and during that found that two of the injectors were spraying neat fuel, and were basically stuck open.
itisgeorge
Another question re the oil extractor! I have everything I need to complete it now, but my driveway has a slight incline and I'm wondering if it would be better to have the front pointing up the incline, or down. Dipstick tube must either go to the front or back right?
Thanks again!
Thanks again!
