Driver side window had drop and won’t go fully up even when engine is on I try to go all the way up but it stops
Any solution?
Windows dropped and won’t go fully up HELPPPP
- Deagol
Re: Windows dropped and won’t go fully up HELPPPP
I think this has been covered in previous posts, but cannot find one right now to link through for you.
BUT
Try running the engine, and fully lowering each window (with the doors shut) and then lifting and releasing the "window up" button so the glass goes up on it's own, until it reaches the top. Hopefully it will be closed properly?
D
BUT
D
Baptised with Aerosmith
As said, use the switch to fully open and close the window to see if it fixes itself. If it doesn't try disconnecting / reconnecting the battery to reset the control module.
The frameless windows are a pain in freezing conditions as the window can stick and not drop as it should or go back up when the door is closed. What I do is make sure the window seals are defrosted before unlocking the car.
