Whats the difference from TSI and R
- In: Pure White
Here in Australia you only get the R.
Re: Whats the difference from TSI and R
The TSI gets the MK6 Engine
The scirocco R gets the mk5 Edition 30/S3 8P engine
- In: Pure White
Interesting.
So the TSI has the dodgy timing chain tensioner, same as our EOS
Yeah The older ones need the revised Tensioner
but other than that they are bullet proof
with the TFSI, they suffer from cam follower wear issues and pcv failing. It also needs an uprated fuel pump unlike the TSI engine
is there a cut-in date for the tensioner?
I want to understand if I need to think about this or not.
I think 2010 or something. not 100%
- Zanic L3
2012 no?Paradox1 wrote:I think 2010 or something. not 100%
dunno for sure. you'll have to research it.
Either are both decent options for tuning.
- Zanic L3
I'm pretty sure its around mid '12 that they fixed itParadox1 wrote:dunno for sure. you'll have to research it.
is there a TSB for timing chain failure?
Just had my tensioner and chain/guides done on my 2.0 tsi as I was unsure about the changeover date. Mine is registered June 2012 and it did have the updated tensioner fitted. Saying that they are now on revision 12 of it !!
- Zanic L3
How much was it? If you dont mind sharing though. Need to get mine done as wellpaul123 wrote:Just had my tensioner and chain/guides done on my 2.0 tsi as I was unsure about the changeover date. Mine is registered June 2012 and it did have the updated tensioner fitted. Saying that they are now on revision 12 of it !!
