Hey guys, i want to hear you're guys thoughts
So, the other day i was cruising and i was shifting in to 5th (i got the 6 speed manual) when i did this i heard a metal screaming sound as i let go of the clutch, as if it didn't hit the gear correctly, not while i was moving the shifter to 5th but when i let go of the clutch after placing it in 5th, and the last week i got the sounds about 7 times.
So i did a test today, i pushed the shifter to fifth using more strength to push it hard forward, and i didn't get the sound a single time..
I think it might be the gearbox wire that needs to be adjusted, what do you guys think?
Metal scraping sound gearbox
Re: Metal scraping sound gearbox
get it checked out at a garage
