Hi. My headlight washers stopped working for a while now. Soon I have to pass MOT and they already warned me that if I go pass MOT again and the headlight washers don't work, my car is not approved. I tried to use VCDS to test the headlight washers so I can see if it is a motor problem or other thing, but I can't seem to find where to do it. Can anyone please help me? I already checked the fuse box and all fuses are good. Also, does anyone have a fuse box diagram?
My car is a 2011 VW Scirocco R.
Thank's in advance.
Enviado do meu SM-G935F através do Tapatalk
VCDS testing and coding (headlight washers)
Re: VCDS testing and coding (headlight washers)
Anyone please?
- I drive a: R-Line
You get this issue sorted
