Rear Spacers - 12mm or 15mm?
Hi guys, I have a 2011 Scirocco R, wanting to fit rear spacers. Not sure if to get 12mm or 15mm. I currently have stock ride height with 19" Telladega wheels, but do plan on getting some H&R 35mm lowering springs at some stage. I rarely carry rear passengers and nor do I carry heavy loads in the boot. How do 12mm sit VS 15mm and which would you recommend? Thanks.
- P44RYT
- I drive a: R-Line
Re: Rear Spacers - 12mm or 15mm?
I had 15mm spacers all round on 19" Luganos, sits fine especially at stock ride height and you won't have any trouble lowering it. You could actually go wider than 15mm, but in my opinion if it's between 12 and 15, go for 15 [emoji1360]
Sent from my SM-G950F using Tapatalk
