Hello all
My Wing Mirror has recently snapped - see attached pic. There is no damage to the mirror itself but the metal that runs inside and connects to the door has broken.
I've been quoted from £160-£350 to fix this problem but figured with some strong glue I could probably fix myself?
Does anyone have experience with this issue? Am I right to think that it can be fixed with glue?
Any thoughts would be amazing
Thanks in advance
Wing Mirror Issue - Budget fix? (Pic inside)
- I drive a: R-Line
Re: Wing Mirror Issue - Budget fix? (Pic inside)
Mine snapped the other day I fixed it with super strong adhesive , you
Will need a adhesive gun and the following from b&q
- I drive a: R-Line
mrsavvy90 wrote:Mine snapped the other day I fixed it with super strong adhesive , you
I put this all inside then used duct tape to keep the wing mirror in place while it dried . Takes around 10 mins to dry but 24 hours to fully dry , but now it holds up fine . Once it’s fully dry , remove the duct tape and you should be fine , this stuff is extreme weather proof , and very strong ,
