Tyre pressure
- SciroccoCW
- In: Oryx White
Tyre pressure
I was wondering what the best pressure for my tyres would be and the info in the fuel cap gives two pressures if the car is holding 2 people, but I'm not sure which one of the top two is needed. I done 36 PSI in the end.
Any ideas?
Yes I forgot to clean inside the fuel cap, don't judge me..
Any ideas?
- Roy_01
Re: Tyre pressure
I don't see it in the manual. Maybe its a different size tire or winter tyres?
- SciroccoCW
- In: Oryx White
Re: Tyre pressure
The manual says to check the fuel cap.. but it gives two pressures for having two people in the car.. it's not very clear!
- Roy_01
Re: Tyre pressure
I think it's for winter tyres.
- SciroccoCW
- In: Oryx White
Re: Tyre pressure
I'll check the manual again!
Thanks Roy
Thanks Roy
- JeffW
Tyre pressure
Deleted my own post. Shouldn't write rubbish after wine.
Re: Tyre pressure
I put 34psi in mine all round
Sent from my SM-G930F using Tapatalk
Re: Tyre pressure
Is the second one maybe the comfort setting? i.e. you'll get a more comfortable ride but I'm guessing that the outside edges of the tyres will wear faster due to having less air in them
- SciroccoCW
- In: Oryx White
Re: Tyre pressure
Not sure. The second one has the little handbook with the information symbol, perhaps the manual explains the second pressure.. haven't had time to check it yet though
- Zanic L3
Re: Tyre pressure
So whats the difference between the both now?
Re: Tyre pressure
That sticker is hopeless, what where they thinking.
Based on my sticker (2009 2.0TSI) first row is winter tyres, 2nd and 3rd row are regular tyres. A 2.0 on 18s is 33psi all round.
Re: Tyre pressure
I've got a different sticker on mine that is much clearer. It lists the various OEM tyre sizes and gives the corresponding pressures for each
I run my 235/35x19 at 35psi.
