I have a 2011 2.0TDI 170bhp GT. When pulling away, and when stationary, with revs at 1300-1600 there is a vibration/rattle from under the bonnet. Seems to be around/under the battery/airbox.
Has anyone else experienced this? Is it common? Whats the cause?
My dad has a 2012 Golf 2.0TDi which does the same - we've taken his apart and can't seem to identify what the cause is (unless its further down in the engine bay).
Thanks,
Brad
1300-1600rpm vibration
- Roy_01
Re: 1300-1600rpm vibration
Could be the heat covering plate on the back of the engine on the exhaust around the turbo/dpf.
Thanks Roy.
Is this part easy to get to? Is it a common problem or is it associated with any other issues?
