Power Upgrades
Power Upgrades
Ive got a 1.4tsi 160 scirocco, and want a bit more power out of it, already got a forge intake, Cat back and a remap, does the forge intercooler make a big difference as there £700 and can't find any cheaper, Also is it possible to drop the 2.0tsi engine or do you have to change control units looms etc ? Thanks
- Phil
- In: Night Blue
Re: Power Upgrades
Not sure for 1.4 tsi, but looked last week on the forge website at the 2.0 and it was 400.
Doubt it will give much power difference however
Phil
Re: Power Upgrades
A bigger intercooler will primarily let you keep the power on during the summer months - it will offer your a few more HP in general but not much.
Unfortunately the next step up from where you are is stage 2, nothing else can be done without doing whats necessary for a stage 2 which gets expensive:
-Sports cat / decat down pipe
-Bigger intercooler (Audi S3/Golf R is a drop in and its what i have done)
Doing the above will also allow you to install a forge wastegate, which will give you a noticeable performance boost by allowing you to hold a much higher boost pressure in the upper RPM's
You would be looking around 250bhp with the above and forge wastegate.
I only recommend going stage 2 on post 2012 CAVD engines as the pre 2012 engines used mahle pistons which are made out of chocolate. Post 2012 they switched to KS which are far better.
To drop in a 2.0 TSI engine will require the entire engine and all ancillaries with full wiring loom, the engine ECU, engine mounts, and probably gearbox (i believe the bell housing is different)
Re: Power Upgrades
Probably cheaper to trade the 160 in against a 2.0 TSI GTblower wrote:To drop in a 2.0 TSI engine will require the entire engine and all ancillaries with full wiring loom, the engine ECU, engine mounts, and probably gearbox (i believe the bell housing is different)
Re: Power Upgrades
Thanks for the advice, wouldn't get insured on a 2.0 tai so would make more sense to swap but its a lot of work, its a 2009 CAVD so yeah not the best engine, is the golf R / S3 Intercooler a straight swap with no modification ?
Re: Power Upgrades
If you swapped the engine to a 2.0TSI you would have to declare it to the insurance and as a modification the risk would be even higher from their perspectiveSamc123 wrote:Thanks for the advice, wouldn't get insured on a 2.0 tai so would make more sense to swap but its a lot of work, its a 2009 CAVD so yeah not the best engine, is the golf R / S3 Intercooler a straight swap with no modification ?
Re: Power Upgrades
Pretty much - only thing you need to do is chop off the crappy metal latching ends (or boost leakers as i like to call them) on your existing charge hoses, like 'last humans garage' did here: " onclick="window.open(this.href);return false;Samc123 wrote:Thanks for the advice, wouldn't get insured on a 2.0 tai so would make more sense to swap but its a lot of work, its a 2009 CAVD so yeah not the best engine, is the golf R / S3 Intercooler a straight swap with no modification ?
Re: Power Upgrades
Probably a mute point as i doubt he has reported the intake, catback and stage 1 remap to his insurerCuprabob wrote: If you swapped the engine to a 2.0TSI you would have to declare it to the insurance and as a modification the risk would be even higher from their perspective
![Wink ;)](./images/smilies/wink.gif)
Re: Power Upgrades
Was just thinking the exact same, a standard 2.0 TSI would be cheaper to insure than a modified 160 TSi (all mods declared)blower wrote:Probably a mute point as i doubt he has reported the intake, catback and stage 1 remap to his insurerCuprabob wrote: If you swapped the engine to a 2.0TSI you would have to declare it to the insurance and as a modification the risk would be even higher from their perspective
Lets all have a slow hand clap for the OP
![Clap :clap:](./images/smilies/clapclap.gif)
![Grumpy :grumpy:](./images/smilies/grumpy.gif)
Re: Power Upgrades
Re: Power Upgrades
Lets hope you never have an accident thenSamc123 wrote:done myself there, does changing the coils make much of a difference seen a few people have put the "R8" ones on is it worth it, and ill look into the the intercooler as it looks a lot cheaper than the forge one
, thanks
![Fall Over :fall:](./images/smilies/faint2.gif)
As for the coils, other than they are Red not Black, no, R8 coils make fuck all difference, it's still just a coil pack
Re: Power Upgrades
I m using s3 8p' intercooler and its easy to install.Total cost was like 350€.You could also buy a front mount cooler and get the same results at the same cost.Intercooler itself gives no hp but it allows your tuner to increase the pressure on the engine since your intake air is now colder
Re: Power Upgrades
Going to try and source a S3 intercooler, is anyone running a decat thinking of that then Revo stage 2 map ![Thumbs Up :yes:](./images/smilies/thumbsup3d.gif)
Re: Power Upgrades
I'd save your money and out it towards insuring it properlySamc123 wrote:Going to try and source a S3 intercooler, is anyone running a decat thinking of that then Devi stage 2 map
