Hi Guys
Had a little search and can't believe i can't find anything on this issue... Maybe I'm being super thick.
How do you get the frameless doors open when the battery is totally dead? Dont want to break the glass!
Frameless doors?
Re: Frameless doors?
Might be wrong but seem to remember someone saying a key hole under cover by side of door handle
- olechr1337
Yes there is a cover by the doorhandle. Used it multiple times during the cold winters in Norway since the locks and windows freeze a lot. Just put a little pressure on the top of the glass to make it easier for it to go over the little edge at the top ![Smile :)](./images/smilies/smile.gif)
I think what the OP is referring to is not the door lock but actually the fact that the window won't drop to allow it to clear the seal when the battery is dead. I believe the only solution is to very carefully pull the door against the seal while trying to prise it up.
- olechr1337
True that. Was not sure about that so as i said, put a little pressure on the top of glass to clear the seal at the top. My glass has not cracked even in -10 to -20 degrees celciusCuprabob wrote:I think what the OP is referring to is not the door lock but actually the fact that the window won't drop to allow it to clear the seal when the battery is dead. I believe the only solution is to very carefully pull the door against the seal while trying to prise it up.
Have a look at "Gummi Pflege". It's like a lubricant for the rubber and is supposed to prevent or at least minimise the window sticking to the rubber in frozen temps. Apply it to the top of the door seal and the rubber edges between the door and the window.
Even if the battery is dead, you can still open the door carefully and get in the car but you should be very careful closing the door as the window will still be up and wont seal under the frame until you sort the battery/freeze issue.
Golf 7R
Gone: Scirocco R
VCDS available
Gone: Scirocco R
VCDS available
