Near side rear wheel bearing hard to change? Help
markinho117
In: Shadow Blue
Post by markinho117 »
Anyone know how to change a wheel bearing in a 58 reg scirocco? Any video or pics thanks
Gaz r
Options: Vienna leather
Rear parking sensors
Re: Near side rear wheel bearing hard to change? Help
Post by Gaz r »
If you do a web search for golf mkv rear wheel bearing removal and refit that should be more than enough. As the scirocco is based on the mkv platform and shouldn't be much different I believe. The wheel bearing is contained in the hub. So a case of remove brake calliper and carrier. Next the disc which will give access to the hub. A new kit should contain a new hub, hub bolt and dust cover.
You'll need some correctly sized tools and preferably access to a ramp or pit as from what I've read it's rather difficult without. Should take about an hour.
