Good evening everyone,
First of all, my name is Tiago Silva and i'm a proud owner of a tsi 1.4 160 Rocco.
I guess we are a lor around here
Since 28th July, My rocco doesn't start, and even VW doesn't seem to know what the problem is.
I have had the engine changed in June and for one month everything seemed to ok but one day after work i was going to start the car but no luck, the engine cranks but the car doesnt start.
In the MFD comes ERROR : ESP. and the cooler fan starts working like crazy for 5mins +/-
I recorded a video so that its easier to explain (watch with high volume) - " onclick="window.open(this.href);return false;
Can you plese help me?
Regards,
Tiago Silva
TSI 1.4 CRANKS BUT NO START - ESP ERROR
- Roy_01
Re: TSI 1.4 CRANKS BUT NO START - ESP ERROR
Try a new battery, check fuses and scan for fault codes.
HeycRoy_01,
Thanks for the answer.
Already switched the battery and the fuses at VW.
Friday i've paid 940€ for a new ECU cause VW said the it was faulty and saturday (yesterday) the same problem occured.
The rocco was already 3 times in VW and they dont seem to figure the problem out.
Thank you
Thank you
You got any retrofits on the car?
Hello aaimson,
What are retrofits? sorry for my ignorance..
The car is completly stock..
Ah, I meant like upgraded Nav or stuff like that
No, nothing..
Have any clue of what's going on?
Probably poor ground somewhere - check engine ground strap to battery / chassis.
Check starter motor grounding and power.
Check grounding terminal on top of the engine for the coil packs.
Sounds like a software issue to me.
