Morning All,
Well it looks like the clutch is on its way out over the last few weeks where its slipping on load in 3 and 4 gears and even in 6 if the foot is planted on the motorway.
The engine has been remapped and think its found the weakness as the power is there but clutch is a little behind.
Just wondering has anyone had the clutch replaced and costs i will be expecting to payout and or what clutch upgrades people have put into their motor?
Haz
Slipping Clutch
Re: Slipping Clutch
What stage are you at with the mapping as a stage 1 should be fine with a OEM clutch, If you are planning to go to stage 2 or above then you will need to be looking at a uprated clutch, Sachs are a good bet but are on the expensive side ! (check awesome car parts ) http://www.awesomegti.com/" onclick="window.open(this.href);return false;
Good luck.
Good luck.
Re: Slipping Clutch
Just had the engine remapped from 210 - 265BHP so initial Stage 1...
Just had a quote from VW £843 iNC VAT.. doesnt seem to bad and expected cost...
will have a look at awesome, they fitted the coilovers recently.
Re: Slipping Clutch
Had mine done on the Scirocco R - £1300 in total. £800 ish for Helix Clutch from Awesome with standard DMF and Release bearing. Then the rest in labour. Quoted 8 hours for the job.
Re: Slipping Clutch
Yeah looked at the Sachs and Helix clutch but i dont think i would benefit from the upgrade...mattyfitz wrote:Had mine done on the Scirocco R - £1300 in total. £800 ish for Helix Clutch from Awesome with standard DMF and Release bearing. Then the rest in labour. Quoted 8 hours for the job.
Sachs is about the same price at standard from VW so could be tempted but i should get warranty on their part if it goes again...
Re: Slipping Clutch
Had my clutch replaced party under warranty due to slave cylinder leaking, paid £400 for the part no labour.
They put a revised clutch in which seems to feel and perform better than the original! i'm stage 1 15k miles after remap and still going strong.
