RCD510 to RNS315
- In: Shadow Blue
RCD510 to RNS315
Plan to swap my RCD510 for a RNS315 that I have obtained.
On the back of the RNS315 there is a smaller black connector block ... I assume this is for the VW gps sensor? or do I need an additional loom?
Can anyone confirm?
Anyone done this swap previously?
Can anyone confirm?
Re: RCD510 to RNS315
The black connector will be for reversing camera input. The GPS plug is the Blue Fakra plug.
- In: Shadow Blue
I have reversing parking sensors with the RCD510... Although not camera type?Viking wrote:The black connector will be for reversing camera input. The GPS plug is the Blue Fakra plug.
GPS has been ordered for the head unit.
- In: Shadow Blue
Will take a picture in bit.
- In: Shadow Blue
- In: Shadow Blue
Also need to know what coding to change on VCDS for sat nav and for dynaudio to work properly.
I'll be keen to know how you get on with this, and if you can add some notes at the end about your full process.
I have an RCD510 but would be interested in going to a 315 for its built in Bluetooth and sat nav capabilities. I also have Dynaudio so would want that to keep working.
Perhaps the other socket is for a VW CD changer, given that the 315 doesn't accept multiple CD's like the 510 does.
- In: Shadow Blue
I think the socket is for the Bluetooth microphone from searching... just ordered the microphone kit (genuine) ...
Plan to scan the RCD510 for the coding so I can see what options are ticked under long code helper before I remove it so I have a reference to work too ... it should be mainly change sound to 'dynaudio' and enable sat nav options / Bluetooth on MFSW.
A job for tomorrow afternoon once the security code, microphone and GPS sensor arrive...
Twin white Fakra is the AM/FM aerial, blue Fakra is the GPS antenna, black Fakra is the DAB aerial, black multi plug in between these is for the reversing camera input, Quadlock connector is for all other inputs/outputs such as speakers, CANBUS, microphone, MDI, AUX, CD changer etc.
- In: Shadow Blue
Thank you sir!Viking wrote:Twin white Fakra is the AM/FM aerial, blue Fakra is the GPS antenna, black Fakra is the DAB aerial, black multi plug in between these is for the reversing camera input, Quadlock connector is for all other inputs/outputs such as speakers, CANBUS, microphone, MDI, AUX, CD changer etc.
- In: Shadow Blue
Anyone got a guide / link for fitting the microphone and loom?
- In: Shadow Blue
Ok, so got it all fitted ... Set sound to dynaudio, etc. with VCDS and got warning about module not being coded... Assumed because of the Rns315 ... Everything works, but no sound.
Any ideas?
Any ideas?
Do you actually have Dynaudio fitted in your car? Can you post a scan log?
- In: Shadow Blue
Yes I do ... Will post can in moment. Wish could find out how to reset this rns315!!'Viking wrote:Do you actually have Dynaudio fitted in your car? Can you post a scan log?
- In: Shadow Blue
Error codes...
Code: Select all
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K098070AF2
Coding: E9A81F06500612004001
Shop #: WSC 00020 790 12345
VCID: 66C62289514C6F0EE4-8032
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 162102 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 1K8 920 971 A HW: 1K8 920 971 A
Component: IMMO H05 0207
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 316C81D56002F8B6C1-8064
No fault code found.
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667500564
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2646628951CCAF0E24-8072
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 G HW: 3C8 035 279 G
Component: RNS315-EU H76 0410
Serial number: VWZAZ2N0601156
Coding: 040500110100040000009002
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2F6887AD7636EE46D7-807A
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V5 0055
1 Fault Found:
1048659 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
- In: Shadow Blue
Current settings under (17) Nav:
byte 1 - dynaudio sound system
byte 2 - sound system, active speakers
byte 4 - speaker monitoring inactive
Since changing, no sound. I've tried putting them back how they were, no sound. It seems something has disabled the sound but I cannot find out what and no knowledge on how to reset the stereo.
Typically I need the car tomorrow, so if I cant get this sorted I will have to rip it out and put the RCD510 back in!
Full scan log would be a big help...
- In: Shadow Blue
Sound has come back on... As soon as I read navigation controller the sound went off?
Although if you have a setting for Dynaudio Sound System (BAP DSP) I would be trying that first instead of Dynaudio Sound System.
- In: Shadow Blue
Well it's working now. No idea why lol ....
