Click on 09-Cent. Elect.
Click on Coding 07
Click on Long Coding Helper
Select Byte 23 (circled below)
Make sure Bit 2 is checked and select 08 Turn Lights via Fog Lights for Bit 3-4
Now, when your headlights are on the left/right fog light will illuminate either when you turn the wheel in that direction (below a certain speed I think), or you have you indicator on for longer than 3 flashes. The bulb fades on and off rather than turning on and off instantly
