There is a topic on the Roccopedia on "Light Bulbs Used on the Scirocco" but it does not cover the rear light bulbs.
I would like to keep a spare or two and wondered if anyone had the information as to what the bulbs are.
I realise that I could take the rear assembly and check the bulbs but I read elsewhere that is fiddly and a chance the lugs will break off so thought I would check here first before attacking the car. The other way would be to go into somewhere like Halfords and have a look at the little books they have next to the bulbs. I checked on a few websites of bulb suppliers/manufactures and they don't list the 2008 on Scirocco, only the Mark1 and 2 so I guess they have not got their act together yet.
Peter.
Rear Light Bulbs?
Re: Rear Light Bulbs?
how about your manual?
Yep. When you've tried everything else ..... have a look in the manual
The manual was the first place I looked (before making the original post). For some reason it gives details of most of the front bulbs but not the rear hence my question. I finally pulled the rear lights out and here are the results:
Tail Lights: P21W (382)
(3) for each side - inner and outer ones also double up as brake and rear fog
Rear Turn Signal: PY21W Amber (581)
Reversing Lights: W16W (955)
Perhaps these could be added to the Roccopedia topic on bulbs? If so to complete the list please add
Front Turn Signal: H21W
and on Xenon vehicles
Static Cornering: H7
Daylight Running Lights: P21W
