OBDEleven on way .. help please
Jacko5
Options: Heated Leather Interior.. Winter Pack .. Panoramic Sunroof .. RCD 510 Radio
Post by Jacko5 »
Ok i have a OBDEleven on its way to me.
I want to disable the DRLs and don't have a clue how to do it.
This is the plan.
1. Disable the DRLs.
2. When the LIGHT SWITCH is in the 0 position all lights OFF.
3. Have Auto Lights as they are meant to be, AUTO SWITCH ON and lights only come on when its dark.
4. When the LIGHT SWITCH is in the side light position ... rear, front lights as side lights as they are now with also the small lights it the front bumper on ( like when DRLs are on ).
Hope the above makes sense :eek: .
Thanks for any replies.
Scirocco TSi 1.4 ... Rising Blue ... Decent Spec.
Roy_01
In: Sumatra
Re: OBDEleven on way .. help please
Post by Roy_01 »
You can also disable drl with lightswitch in off position.
Only works in auto position then but you want to disable full functioning?
Jacko5
Post by Jacko5 »
Roy_01 wrote:You can also disable drl with lightswitch in off position.
Yes thats what i have said above, lights all off in 0 position and auto position to work as it should be,lights on when it gets dark.
I found these commands,not sure what they mean yet,
Emergency Break/Flashing Lights
Select Control unit 09 (Central Electrics)
Control unit Long Coding
Byte 16
Bit 1 Activate
Bit 2 Activate
Byte 23
Bit 5 Activate
Rain Close
Byte 4
Bit 5-6 Activate
Seçim Control unit 09 (Central Electrics)
RLS Sub Selection
Byte 0
Bit 2 Activate
Sync Mirrors
Byte 8
Bit 6 Activate
Cornering Lights with Fog-2010 and later
Byte 14
Bit 7 Activate
Byte 12
Bit 4 Activate
Cornering Lights with Fog-2009 and before
Byte 23
Bit 2-Bit 3-Bit 4 Activate
Locking Door up to 15 km/h
Byte 0
Bit 2 Activate
Unlocking Door when Stop the Car
Byte 0
Bit 1 Activate
Activation of Coming Home/Leaving Home-2010 and after
Byte 12
Bit 2 DeActivate
Byte 17
Bit 5 Activate
Activation of Coming Home/Leaving Home-2009 and before
Byte 23
Bit 5 DeActivate
Coming Home/Leaving Home with Fog Lights
Byte 17
Bit 3 Activate
Lock Acknowlegde with Horn
Byte 5
Bit 1-Bit 4 Activate
Adaptation
Channel 10-Sound when unlocking
Value=1
Channel 11-Sound when locking
Value=1
Disable Seat Belt Warning
Select Control unit 17 (Dashboard)
Byte 1
Bit 1 DeActivate
Activation of Tear Wiping
Byte 1
Bit 3 Activate
Byte 21
Bit 4 Activate
US Parking Signals
Byte 07
Value 28
XDS Activation
Select Control unit 03
Byte 17
Bit 3 Activate
XDS Adjustment
Select Control unit 03 (ABS)
Adaptation
Select: Expanded Electronic Differential Lock
Options: Weak-Normal-Hard
Pointer Test
Control unit long coding
Byte 1
Bit 0 Activate
I think most of the above listed are self - explanatory and some of the items can already be changed if you have highline MFD.
Pointer Test - Needle Sweep
Rain Close - Close windows and Sunroof if rain sensor detects rain.
Tear Wipe - After using washers a delayed final wipe to clear screen
Sync Mirrors - When you adjust driver's mirror passenger mirror automatically compensates.
Emergency Brake / Flashing Lights - During emergency stop brake lights and hazards flash
XDS - electronic different control and setting.
Roy_01
In: Sumatra
Post by Roy_01 »
Cuprabob wrote:I think most of the above listed are self - explanatory and some of the items can already be changed if you have highline MFD.
I tried the brakelight flashing a time ago but it doesnt work on my MY10, only the hazardlight flashing works. Im not sure that the pointertest byte 1 bit 0 coding is correct i thought it was an adaptation channel indicator celibration or staging.
Roy_01
In: Sumatra
Post by Roy_01 »
FYI: Module 17 byte 1 bit 0 is brakepad warning active
chelspeed
Options: Sold it!
Post by chelspeed »
Isn't it OBDII? OBD2, ie a Roman 2 rather than Eleven? Or is OBDEleven a trade name?
chelspeed wrote:Isn't it OBDII? OBD2, ie a Roman 2 rather than Eleven? Or is OBDEleven a trade name?
Trade Name
Jacko5
Post by Jacko5 »
Right i sussed it out.
For anyone who wants to use a OBDEleven gadget here is the info for DLR Disable
I found out how to disable DLR Lights in my 2009 Scirocco.
central electrics
long coding
byte 0
bit 03 untick
What this does is,
light switch position
0 ... all lights off
auto .... lights as they should be .. off in the day .. active when dark.
side light ... rears on ..front only lights under bumper on .. no headlights on at all.
Hope this helps someone.
Will post more codes for OBDEleven when i suss any out.
Jacko5
Post by Jacko5 »
Further to this thread...
My brakes are very keen and i have done Brake Assist from normal to weak.
I have also seen that brake boost is enabled i have tried to disable this but need a access code .. does anyone know the access code for my 2009 Scirocco ?
Or a way to find it ?
Thanks.
Edit,
I have just been out in the car.. the brakes are much better with weak position on brake assist setting.
So anyone who thinks there brakes are to keen try the above.
I still need access code help though.
Roy_01
In: Sumatra
Post by Roy_01 »
Why do you want to disable the brake boost? Then you have to perform very much force to get a good braking.
I like the keen braking and put it to strong, so it reacts very quick and i don't have to push in the pedal so far.
But it's personal taste how you want to set it up. I don't have the security acces code, searched for them on the internet but haven't found anything yet.
Jacko5
Post by Jacko5 »
Roy_01 wrote:Why do you want to disable the brake boost? Then you have to perform very much force to get a good braking.
Cheers :D
I will not do brake boost thing.
If you find access code let me know :)
Quinnaay
Leather Interior
RNS315
Post by Quinnaay »
could do with some help, i went in to the settings to disable DRLS unticked bit 3 and now my central electrics module isnt responding :( cant even go back to alter and and nothing changed with regards to the DRLS.
ridavey
In: Opal Silver
Options: N/A
Post by ridavey »
Jacko5 wrote:Further to this thread...
Thanks.
Edit,
Did you find the access code?
Sent from my SM-G935F using Tapatalk
ridavey
In: Opal Silver
Options: N/A
Post by ridavey »
Cheers :D
Did you find the code?
Jacko5
Post by Jacko5 »
Sorry no i did not.
Not messed with obd for a while.
