Turbo trouble
Turbo trouble
Hi I own a 140 tdi and in starting to have trouble with the turbo... The problem is its boosting late and on occasion throwing itself into limp mode, but with a turn of the key it's fine again? I've had it plugged in and it said boost pressure sensor with is the n75 sensor which I have changed but still no change. Can anyone help?
Re: Turbo trouble
Also could anyone with a 140 tdi tell me when there boost kicks in because I've had the problem so long now ive forgotten
- AlanH
Re: Turbo trouble
I'd get it plugged in and checked on VCDS.
Are you getting a flashing amber EML?
Could be a sensor, could be that the turbo is fubar'd. Until you plug it in you won't know properly, and it's pointless spending money on bits if they're not the right ones.
Mine: Scirocco 1.4TSi
Others: Fabia MC BE, Citigo BE
Mods: OE sunshades, LED interior/exterior lights, Dectane rear clusters, K&N panel filter, Milltek catbak NR, 35mm H&R springs, 98RON REVO Stage 1, HP Dashcam
Re: Turbo trouble
Yeah I've had it plugged in twice already both times have said n75 boost pressure sensor which I have changed, but yeah when it goes into limp mode the glow plug (Spring shaped) light flashes not the engine management
- supermoto552
Re: Turbo trouble
Sticking turbo vanes or dirty egr maybe, my old 140 golf had the same issue...cleaned it out with mr muscle and it was fine after.
